FluxCapacitor
- Jun 6, 2021
- 5
I am strongly considering building my first 100ah battery with these modules from battery hookup.
I have a few questions:
NEW CASE OF 4 BATTERY HOOKUP 3.2V 100ah MODULES
Shipping only available to the United States and Canada. Shipping out of the country requires these to be shipped via freight. For a quote email us at sales@batteryhookup.com. No compression needed since these are cylindrical cells which means these are the easiest batteries to assemble, all you...
batteryhookup.com
- Because these are pre-built modules with leads, am I wrong in assuming I can treat them as if they were prismatic cells. (i.e. the positive and negative wires are equivalent to the positive and negative wires on a prismatic cell)? Basically, am I correct in assuming I can hook up a 100A 4S BMS as shown on Will's site here: https://www.mobile-solarpower.com/design-your-own-12v-lifepo4-system.html
- For the most part, this seems pretty easy. Top balancing the cells seems straight forward. Installing the BMS seems easy... What are the main gotchas or easy ways to go wrong here?
- My main concern is safety: What are you main safety tips when working with these cells? What things should I do / not do to keep myself safe when doing this?
