Dc does not flow on the surface, it flows equally through the whole cross sectional area.
There are arguments both for and against soldering crimp connections, and all the usual reasons given are valid.
If you have the correct crimper jaws, to suit both the exact cable size and crimp lug, you cannot do any better than that.
The problem is, there are so many different types of wire and cables in various sizes, gauges, metric and imperial, for different numbers of strands and sized strands. Crimp lugs come from all over the world in different sizes, and so do the crimping tools.
If you mix up the parts, your chances of making a perfect reliable crimp joint are pretty near zero.
Crimping is used in the heavy electrical industry, in the automotive industry, in aircraft, military, and aerospace. They use very expensive tooling, and both the wire and the lugs are supplied to some exact specification. Done well its the most reliable system.
Its not likely that the cheap Chinese stuff you bought on e-bay or Aliexpress is all compatible. But good luck trying.
For us, soldering, or crimping and soldering is arguably the most reliable joint, if the soldering is properly done. The heat does weaken the copper though, and reduces the flexibility of stranded cable right at the weak spot. So in vehicles or where there is a lot of vibration or motion soldering heavy wire needs some caution. One or more layers of heat shrink over the joint helps a lot to prevent bending and eventual metal fatigue right at the weak spot and is recommended.
