Excellent context, thank you.
I have a travel trailer with 50 amp service. Picked it up in the fall so the system is your traditional OEM to get it off the lot, no inverter and a single deep cycle marine battery. If you're managing with 440ah of lead acid I feel anecdotally I'll be fine. My current plan is Multiplus 12/3000, 150/60, 800 watts of solar with room to move to 1200 watts and batteries ... well that's why we're here
I've been looking into the larger BMS's, the brand you mention pops up often. It's pricey but that isn't the reason for my hesitation, I am concerned about the risk and complexity of introducing an external relay. I haven't spent enough time researching them to understand how they handle failure, fail closed as an example. Curious, you're designing for a single bms to manage two batteries? Didn't know that was possible.
