I needed to get some panels up in a hurry for some charge testing that I have planned. I had some aluminum frame sections that someone had given me. They have a slot that a 5/16" carriage bolt will slide right in. So I laid them out on some concrete blocks and anchored them with some screw in anchors.
The north anchors are adjustable so I can keep them cranked down pretty tight. The south attachment is tight because of the block height and what happens when I tighten down the eyelet bolt. The angle is set a little toward winter, 35 rather than 30 degrees from horizontal. They are on the bank right behind the house, but up enough to be in the winter sun.
