Dude if we didn't have a basement I have no idea where we'd put all our extra crap and storage! I guess the garage would have no chance of actually having the car in it...simple fix, don't build a basement that could just flood anyway! :D
? For many people building on hilly terrain just trying to get your site level results in adding or taking away a lot of dirt. You might as well build a basement while you’re at it. I basically doubled my square feet when I built my house for hardly any extra money. And since I live in tornado alley, we have a heck of a storm shelter now.simple fix, don't build a basement that could just flood anyway! :D
The risk with short-term tests is that you test during a low period. If you test at 8, then you need to mitigate. The only thing to test might be to confirm you didn't get a bad test.$15, you set it up then mail back after 96 hours. We came in at 8.3 so now I've deployed a long term test in the same location to see if we can repeat it.
I agree however you appear to have missed the point of my post. Read it again.The risk with short-term tests is that you test during a low period. If you test at 8, then you need to mitigate. The only thing to test might be to confirm you didn't get a bad test.
The cost to mitigate most homes is around $1,000. Exhaust pipes now look like gutter pipes, so blend in better. Get it done, and you don't have to worry about it. All new homes should have it done during construction.
It’s a choice until it’s over 9 (I think) in NC then it’s mandatory.so you're left with basically two choices:
1) Mitigate the radon concentrations.
2) Don't smoke.
Which do do you think is the more economical?
I did read your post, you made a general observation on the cost to remove radon. Radon occurs from two distinct sources in most homes. Vents that look like gutters may work fine to remove soil gases coming into the basement but will do nothing to deal with radon coming in with a water supply. In most cases the radon coming in with the water is more of an issue as it comes out readily in showers and fixtures directly into the occupants face. Subslab ventilation is not going to do a lot for radon introduced into the building from water.I agree however you appear to have missed the point of my post. Read it again.
I don’t see where I made any observations, general or specific, about the cost to remove radon. ?I did read your post, you made a general observation on the cost to remove radon.
You did mention a long-term test to confirm. IMHO, a short term test to confirm. If you have under 2 on the second, then a third short term (don't know which of the first two is correct) and long-term to confirm no need to mitigate.I don’t see where I made any observations, general or specific, about the cost to remove radon. ?![]()
If testing was expensive that would be a logical approach.You did mention a long-term test to confirm. IMHO, a short term test to confirm. If you have under 2 on the second, then a third short term (don't know which of the first two is correct) and long-term to confirm no need to mitigate.
With all this testing, you might as well just mitigate, and not worry about it.
“It should also be noted that radon remediation significantly increases lung cancer mortality. To dispel the fear and eliminate this economic burden, the action level should be raised by a factor of at least seven, where the health benefit is near optimum."
Figures I'm in zone 1 in my statesHere's a radon map that I pulled off the web from a Google search.
I suppose if you're in the areas that are red, then you might want to look into getting a radon test. If you're in the other areas, don't worry as much.
So you have 5% of the cost of mitigation for testing. Unless you are certain that the 8 level test is an anomaly, you will need to continue to spend for testing ever year or two unless you mitigate.If testing was expensive that would be a logical approach.
But I’ll have less than $50 in testing after the long term test is done so I’m going to hold off for another month until the 2nd test (the long term) is done. We don’t smoke or spend much time in the basement.
I'm just followng the testing lab's recomendation which is that at my level you should deploy a long term test before making a decision to mitigate.So you have 5% of the cost of mitigation for testing. Unless you are certain that the 8 level test is an anomaly, you will need to continue to spend for testing ever year or two unless you mitigate.
my basement has an 8" concrete ceiling with 2 layers of rebar on 12" centers since it's also our tornado shelter. Punching through there is not going to be easy or cheap.
[ Rhetoric suggesting that intentionally exposing humans to higher levels of radon is ethical ]
[ Link to American Council on Science and Health website allaying fears of radon exposure at home ]
The American Council on Science and Health (ACSH) is a pro-industry advocacy organization founded in 1978 by Elizabeth Whelan.
During the 1940s, the canal was purchased by Hooker Chemical Company, which used the site to dump 19,800 t (19,500 long tons; 21,800 short tons) of chemical byproducts from the manufacturing of dyes, perfumes, and solvents for rubber and synthetic resins.
In 1998 Dr. Elizabeth Whelan, founder of the American Council on Science and Health wrote an editorial asserting that the media triggered hysteria among the residents when it called Love Canal a “public health time bomb”, and that illness among the residents was caused less by chemical waste than by stress – this in spite of an EPA study showing that 33% of the residents had undergone chromosomal damage.
Love Canal is a neighborhood in Niagara Falls, New York, United States, infamous as the location of a 0.28 km2 (0.11 sq mi) landfill that became the site of an enormous environmental disaster in the 1970s. Decades of dumping toxic chemicals harmed the health of hundreds of residents;[1] the area was cleaned up over the course of 21 years in a Superfund operation.
this woman is literally haunting people from the beyond, they passed away in 2014.best known for promoting science that was favorable to industry
Extraordinary claims.
A comment below the article:
"I'm trying to figure out this statement: "It should also be noted that radon remediation significantly increases lung cancer mortality." I'm not on any particular side here, just wondering the facts behind the idea that reducing radon decay products from being inhaled increases cancer mortality. Thanks!"
From the article:
'Arbitrary standards such as these ignore thousands of studies disproving LNT and demonstrating radiation s hormetic effect that a "toxic" exposure at high levels can be beneficial at lower doses. Hormesis applies to radiation, too. Dr. Cuttler has asserted that no harmful health effects have ever been detected in high natural radiation background areas, most notably (for the American Council, anyway) in his publication, "Nuclear Energy and Health, and the Benefits of Low-level Radiation Hormesis." Compared to average-dose regions, rates of both cancer and congenital disease are consistently decreased, rather than increased.'
The linked article
... could not be found, but searching for it seems to have found it:
https://pubmed.ncbi.nlm.nih.gov/19343116/
(abstract)
"Radiation hormesis is explained, pointing out that beneficial effects are expected following a low dose or dose rate because protective responses against stresses are stimulated."
(full article)
tl;dr:
Cancer deaths are lower in counties with higher natural radon exposure.
Being "vaccinated" with radiation produces an immune response.
Spreading Calmness, Uncertainty, and Doubt?
