timselectric
- Feb 5, 2022
- 18,423
Compared to what?I tried the same, but mine just seemed like it was never accurate, always +/- 3-5% it seemed.
I see now. Ah is a test measurement that tracks the amperage output of the battery, where watt-hour is a test of watts over the measuring tool.
If the tools are both directly connected to the terminals of the battery, I can measure the Wh of the system, but that will NOT be an accurate Ah measurement of the battery.
I’ve never seen an Ah measuring tool…
Compared to a half dozen different BMS's, the Sol-Ark's internal shunt, and the fact that it says I have 10-15% battery remaining sometimes when the voltage is at 48v. I don't remember exactly, but it was things like that.Compared to what?
A bit off-topic, but one of the things that drove me crazy about lead-acid was that the manufacturers used such odd-ball specs and then gamed the system. Most batteries were rated in for a "20h C-rate", meaning that the Ah rating was an indication that if you drained it that Ah divided by 20, it would last that many hours. Whaaaa? I'm sympathetic in that peukert showed the battery will deliver fewer Ah at higher A rates (unlike LiFePO4, which are mostly constant), but this just made it so no one really knew how much they could get from their batteries. Worse, people could just claim a 20H rate and who would ever check to see? Arghhh. It's frustrating to think of the money I've wasted on lead-acid.Lead-acid used to have testing standards set by BCI such as the AH rate of discharge in hours or the constant current RC rating.
Has all that just gone away? Or has our interpretation gone sideways?
BMS's are terribly inaccurate. Not sure about Sol-Ark, but I would trust Victrons accuracy over anything else.Compared to a half dozen different BMS's, the Sol-Ark's internal shunt, and the fact that it says I have 10-15% battery remaining sometimes when the voltage is at 48v. I don't remember exactly, but it was things like that.
What about the 10-15% capacity when the battery clearly is near dead?BMS's are terribly inaccurate. Not sure about Sol-Ark, but I would trust Victrons accuracy over anything else.
I assume that most would agree.
At 48v, each cell is at 3v. 10-15% is about right.What about the 10-15% capacity when the battery clearly is near dead?
I recently pulled a 48v 100Ah pack apart that I built and used with a Growatt SPF 5000ES for about 8 months. Wanting to sell the the cells I had to determine the capacity for the buyer. All in all I had to test 24 cells ( had a few spares ) . Using the ZKE EBC-A20 I tested each cell as follows : Charge the cell up to 3,6v , constant current of 5A , until the tail current dropped to 0,7A , rest the cell for about 10 - 15min. Discharge cell to 2,8v at a constant current of 20A until the ZKE turned off. After, the test the results are displayed on the screen in Ah and Wh. You can then calculate the nominal / average voltage by Wh/Ah. All cells tested between 93 - 102 Ah . Could also have plotted all the graphs on the PC but needed it elsewhere. Took a few days to do !!I see now. Ah is a test measurement that tracks the amperage output of the battery, where watt-hour is a test of watts over the measuring tool.
If AH is the most important
a 24v 200AH battery is 5120W and a 48v 100AH battery is 5120W they have equal output.
If the AH is more important or the deciding factor however it is looked at then the 200AH battery has twice the capacity of a 100AH battery?
