Suijkerbuijk
I cannot be held responsible for this information.
I have beult my Raspberry pi4b with screen and heatsink's for the victron mppt and inverters
This is a topic how i have beult .
What you need .
How its done easy .
Links from Dutch Amazon parts
But i set the parts numbers with it .
So the start .
Whats is a Raspberry Pi serie
Its really a mini pc arm base systeem that you can beult and program .
In this case we gone make one with Victron venus os support.
Its a cheap solution for the venus gx systeem what cost a lot of money.
In that attach files you see what i use for the this beult .
I set YouTube from other people that help and explain more than i can do .
Its more easy that way and my English is not all the best .
For the rest the systeem is working process means i adjust over time .
I use a Raspberry pi4b and not a Raspberry pi5 serie
The reason is heat and the power use from the pi5 that use a lot more and have to be active cool.
And you do not need that extra power for the setup
So what i gone use for this.
Raspberry pi4b 2Gb model
A heatsink for this unit
A case with a 4.3 monitor (have the space for a heatsink)
And somting to power this systeem .
The victron venus os see link
The install software see link.
sourceforge.net
For diy cheap usb to ve-direct cables see link
I make my own cable
Do not gone pay a Victron cable for 30/40 euro
This cost about 10/15 euro .
And its work on a Windows 10 systeem
Proof that it work
For people that like a hub.
This model here you can order.
www.duppa.net
Waveshare 4.3 Inch Touchscreen DSI LCD met Case voor Raspberry Pi 4B, 800 × 480 Resolutie IPS Monitor Capacitieve Scherm
The heatsink i use my self
Geekworm Raspberry Pi 4 11mm Embedded Heatsink (P165-B)
Other model you can use.
Geekworm Raspberry Pi 4 Embedded Heatsink (p165-A) 7mm and 14mm with fan
You can use multi wifi adapters.
One in your Raspberry Pi and a usb .
This way if you like you can make a fall back system.
In my case if i'm thare the wifi onboard of the Pi connect to my phone .
If i'm away the other usb wifi adapter go to the wifi point from the port whare my boat is .
Its switch automatic .
How it works
First install the os.
Than connect pi wifi first to a network.
After that stick a usb wifi in .
And select a other wifi point for that one and your done
Support list see link for wifi chips .
github.com
Support usb adapter bluetooth
List of tested dongles by Victron, that work:
Logilink BT0037
Ewent EW1085R4
Laird BT820
Laird BT851
ASUS USB-BT500
TP Link UB400 (CSR8510 A10 c chip)
Oke if the systeem start you have to setup the display to active .
If not you only see Victron on it and nothing more .
The YouTube show you and explain you how to active it .
If the screen is upside down.
Use this code in root .
nano /u-boot/config.txtlcd_rotate=2
Or use this see link
github.com
For shutdown function in to venus os.
So you can shutdown the pc .
The code is here .
off-grid-garage.com
Oke for people that like to make a back up for your total install from your systeem see link how to do it .
chem.libretexts.org
github.com
Setup helper .
See link
And see link here what it do
communityarchive.victronenergy.com
And
Oke some ask about relay box
Here it is
I do not use this my self.
For bluetooth support thare somtings that works.
And have officially support bij the venus os
Mopeka Ultrasonic Bluetooth Sensors
The Mopeka sensors feature ultrasonic sensing for pressurised and non-pressurised tanks and various tank commodities. Depending on the model, the sensors are attached to the bottom or top of the tank. The liquid level, temperature and sensor battery voltage are streamed wirelessly to the GX device.
And
Wireless Bluetooth Ruuvi temperature sensors. The Ruuvi sensor features temperature, humidity and atmospheric pressure streamed wirelessly to the GX device
Oke some have problems with a rainbow screen.
Special with hdmi use.
See link for more information .
For boot problems see link.
Small things with venus os and no start.
Venus O/S cannot run from USB mounted drives, it must run from /dev/mmcblk devic
So you need to use a sdcards by the pi series up to pi4b .
Warning i upload multi time for i'm done with this .
So long this teks on it at the end .
I'm not done write this
Thank you for understanding.
What you need .
How its done easy .
So the start .
Win32 Disk Imager
Download Win32 Disk Imager for free. A Windows tool for writing images to USB sticks or SD/CF cards . This program is designed to write a raw disk image to a removable device or backup a removable device to a raw image file. It is very useful for embedded development, namely Arm development...
I make my own cable
Proof that it work
Isolated 4 port USB to TTL UART FTDI - DuPPa
What makes it special? Each port has the digital isolator. The computer and your target board are electrically isolated. The 4 ports can work at different voltages and the ground is not in common. The noise coming from your computer doesn’t enter in your target board, this can be useful when you...
- Suijkerbuijk
- Forum: Show and Tell
How it works
USB-WiFi/home/The_Short_List.md at main · morrownr/USB-WiFi
USB WiFi Adapter Information for Linux. Contribute to morrownr/USB-WiFi development by creating an account on GitHub.
Logilink BT0037
Ewent EW1085R4
Laird BT820
Laird BT851
ASUS USB-BT500
GitHub - kwindrem/RpiDisplaySetup: Raspberry Pi 7" touchscreen for Venus OS (also HDMI)
Raspberry Pi 7" touchscreen for Venus OS (also HDMI) - kwindrem/RpiDisplaySetup
The code is here .
Victron Venus OS Shutdown Feature
If you just pull the power cable out of your Raspberry Pi running Victron Venus OS, it can corrupt the SD card and the system won’t start any more. This is how I used to shutdown my Pi in the…
4: Clone SD card with Win32DiskImager
GitHub - kwindrem/SetupHelper: Helper functions to simplify writing setup scripts that modify VenusOs functionality. The package includes automatic reinstallation of the package after a VenusOs update.
Helper functions to simplify writing setup scripts that modify VenusOs functionality. The package includes automatic reinstallation of the package after a VenusOs update. - kwindrem/SetupHelper
See link
SetupHelper with Package Manager available - VictronEnergy
SetupHelper v6.0 - VictronEnergy
Here it is
And
