ShaneC
- Nov 3, 2022
- 151
Hi all,
Just wanted to show off my battery as I'm quite proud of how neat it's turned out while also double checking that I haven't messed anything up as its my first go.
It consists of 8x 280ah Eve B-grade cells, about £950. Bought from fogstar.co.uk they came capacity tested, batched and balanced. I am using a JBD SP22S003B 100A BMS. Yes it came with just 8awg cables, I have another thread here asking about that, yet to hear back from JBD.
Sheets in between cells are recycled HDPE, foam at the top is some of the PE foam the batteries came packed in. I'm not going for serious compression but it does hold them well in place. I've taped each 2 sets of cells with heavy duty packing tape then 2 of those into each of the 4x cells. The two sets of 4 are not taped together just pushed together by the case. Went with a flexible 4awg cable in between in case of movement.
This is for use in my office so isn't designed for lots of movement or vibrations, I'd definitely pack it out with more padding if so and tape the two columns of cells together if I wanted to put this in a van.
All in this came to just over £1000 for a 7kwh+ battery. Not bad!
