Jockmacrea
- Jan 6, 2022
- 23
I managed to get hold of failed a 24v 40AH golf buggy LifePo4 battery pack from my pal hoping to to salvage some cells.
I Stripped it completely cleaned up all the cells and here's what I got,
40 cells @ 3.2v or slightly above
20 cells from 2.4v to 2.6v
Remainder all at 1.6v or below, lowest cell voltage was 1.4v
BMS PCM-L10S80-664 was fitted.
The first 40 cells I hope I can use to make a 12v 40ah battery (New Bms will be needed I expect)
If this is feasible can someone please let me have a cell layout using all 40 cells.
Are the remaining cells Junk. ? Can they be saved. ?
I'd like to use the finished battery with my Solar panel (340W) and inverter to output 240vac
This is probably been posted a thousand times so please forgive me.
Many thanks
Many thanks
