Has anyone here ever re-purposed any UPS's for use as an Inverter ?
I acquired long time ago a new, never used APC 1400 rack mount 24v. it's good for 950W
I like that it can be cold started with out any AC input. I'm using it in one of my small solar projects.
I'm using 3 of the 295 watt panels i got earlier ( Canadian Solar ) and 4 100Ah batteries in a 2s2p configuration ( 24v 200Ah )
I got a good deal on a MPPT charge controller , it's good for 50A.
I got lucky and scored 2 free cabinets. one is a small truck box, the other is a NEMA3 DOT cabinet.
I'll share pictures later on.
I had to disable the beeper in the inverter, and the battery gauge it way out of calibration.
It started off full, but after about an hour the battery gauge showed the pack was flat, but the voltage on the controller showed 28.5v
So the inverter battery level meter is not used to a 200Ah battery....lol ( it is supposed to have 4 7AH batteries..) 24v 14Ah.
I wonder if there is a way to re-prorgram the meter on UPS and silence the beeper.
So far things are working ok,, I only have a light load on it right now.. will add more things later on.
Actually have Another UPS plugged into it, and my TV and DVR. 8 Cameras, the UPS seems very happy, it hasn't acted up a bit.
I thought they might not like each other, but it's doing good.
