Hello Everyone,
My name is David. I live in NY, and have property in the Adirondacks that I am building on this year. I am - and have been for a few years - weighing whether or not I want to make this an off-grid build. So, I am reaching out to, well, anyone that will give me their experience with off-grid living to help me make that decision.
My energy needs were calculated based on my family's current avg. energy usage - ~30KWhs per day - and I worked with two different solar engineers to spec out a system. Of course, we factored peak sun hours per day, as they historically occur in my property's zip code. Using 3 days of autonomy, at the lowest avg. sun hours per day (in December), the system came out as: 13KW PV array and ~2000AH of LifePo batteries. Just to be safe, though, I purchased 26KWs of Longi bifacials, thus doubling the array size. Of course, we would have a backup generator as well.
The build will be ~1200 sq. ft., and built very tight, with spray foam insulation.
Why am I considering and off-grid build? I do not have a pole to my property - the nearest being ~1 mile away - and the quote is $180-$200K from National Grid. I know this is a lot, and I am sure that most-if-not-all that are reading this - on this forum, in particular - are thinking "That's ridiculous. Solar is a no-brainer." That said, please consider the rest of my considerations:
(i) When not in use, I will be renting the property. Renters are not energy conscious.
(ii) I will be adding more, but smaller, builds to the property in the future for rental purposes.
(iii) I do NOT want to be constantly thinking about energy usage / conservation when I am using it.
(iv) I do NOT want to be working on the array/inverters/batteries regularly.
(vi) Based on early quotes, between hardware and installation, the solar will cost ~$80 - $100K. This is before tax credits.
With that in mind, and despite my best searching/reading efforts on line, I have yet to find anyone - and I mean, NO ONE - that has said something along the lines of "Well, we have X-size array and Y-sized battery bank, and we never have to worry about power. We threw in central air, and have a hot tub, and we never worry about whether the batteries are drawing down." There seems to always be some discussion about raising the thermostat in the summer during a cloudy stretch; fear of installing heat pumps; no one uses central air - all mini-splits; etc.
So, with that as my back drop, is there anyone on the forum that has (i) built a 1200 ft. + house (not a small cabin) that supports a family, and (ii) has installed a large solar/PV system with a battery back up in the North East that has had a smooth experience? What do I mean by "smooth"? The system, (a) for all intents and purposes run itself without frequent inspection/intervention, and (b) the backup generator only runs, say, 5 or 10 times per year.
If, for instance, I were able to install a system for the cost that I've spec'd, and it ran "smoothly", then I'd likely go with the Solar, and could scale up accordingly for the other builds. But, if real world experience - at a larger scale - finds that the generator is often running, and there are semi-frequent-to-frequent interventions necessary, then I'd likely bite the bullet.
Please know that I write this with a true spirit of inquisition, humility and curiosity. I'd love to have a great off-grid system. Who wouldn’t? But I am building this property as an asset, and with future plans in mind, so I want to do it right the first time, even if that means bending over backwards to do so.
Thank you in advance to anyone that will afford me their time.
