Sunnytheskoolie
- Feb 12, 2021
- 54
Hello,
I have a 32 cell pack, 2s16p at 48V and the BMS is heating up at every charge. It gets up to about 53c while it tries to balance the cells.
I have attached screenshots of the settings I have set in the BMS, do you think that the settings are causing the issue?
Sometimes the pack balances alright as you can see in the last screenshots but this only happens when the pack is drawn down to below 60% SOC.
Thanks for the advice.
PS. The cells are Class A Eve 3.2v 260ah. When I received the pack the voltages were almost all the same so I set the whole pack in parallel for a couple of weeks and then assembled it. I didn't bottom balance or put a charge on the pack while it was sitting in parallel.
