REC - Redneck Electrical Code
Scotch tape is optional if using a plastic lid, just twist your wires together and pop the lid on. If your concerned about rodents use a metal lid with without tape.
Edit - see attachments.
Also duct tape makes a great cover for missing knockouts in a panel.
Put an old metal antenna across your main lugs to change the frequency, works on AC or DC.
Make sure you smash the end of the ground rod with a hammer a few times so the inspector can't tell you cut it off after you hit that boulder a few inches below grade.
Grounding your lightning suppression to your NG line can serve as a great leak detector.
Wire a lamp cord to a single pole switch, plug in off and switch on.. . Breaker finder made easy.
Wow that laugh was worth 5 minutes of searching the interwebs.
Now that is some interesting Jboxes.
I’ve seen some rigged stuff but never a Copenhagen can and wago connectors before.
Electric baseboard heaters may have electrical outlets above them but ONLY that baseboard heater can be plugged into it. This safety measure can be circumvented during power failure.
I call your Copenhagen and raise you a tuna can
If it won't budge, use a longer lever.
NEVER just use brutal naked force to remove anything, its very unprofessional.
Make your wires the same colour everywhere, and never label the function of anything.
It will confuse the enemy.
In the true spirit of the DIY Forum, here is a video of a guy with very gentle hands, lovingly making his own magnesium fuses.
A very worthwhile lesson for us all.....
Breaker panel covers are not required if you're putting breakers in "temporarily" for some reason - can't put those breaker knockouts back in after you take them out, and it looks unprofessional to have holes in the cover.
You want to keep lowering wire size until the wire is nice and hot. Cold electrons are sad electrons.
If you are out of black wire for the negative, red wire is fine
If it is glowing red, chances are you have identified the positive wire.
