ericfx1984
- Oct 10, 2021
- 740
So I have 4 Duracell gc2 wet acid batteries... There's six volts configured to 12 volts
I've had quite a few gray days lately and as a result I've had to use my generator in the morning to charge up the batteries and potentially in the evening as well
The inverter charger can do up to 100 amps continuous of charge.. it is an Aims power one of the things I have noticed about the generator when it's used in charge mode is that it seems to charge significantly longer than it really needs to
Oftentimes it will be in fast charge mode for upwards of 4 hours when the batteries have only been discharged to 12.6 volts.. but for my calculations even at 70 amps it shouldn't take more than two or three hours and if I decide to turn it to the hundred amp setting it shouldn't take but 2 hours at most
So I'm trying to understand why the inverter charger seems to be so heavy on the charge when it doesn't seem to need it
There have been a few times that I've shut the generator off technically ending the cycle early only to find out that the batteries are resting somewhere at or above 12.9 volts
