Could someone recommend a BMS for a 18s 15KW system.
These come as 6 Series 13 Parallel LifePo4 Modules and they are pouch cells trying to separate them to make them 16s would damage them, so I'm stuck putting 3 of these module in series to make them work with a 48v inverter.
Individual cell voltages Nominal voltage: 3.3V Minimum voltage: 2.7V Maximum voltage: 3.6V Capacity 18.7AH
.Module voltage when put in series Nominal voltage: 59.4V Minimum voltage:48.6V Maximum voltage: 64.8V Capacity 244AH
With the whole DALY update debacle I was wondering if there is a alternative BMS manufacturer that is reliable and can do 18s LifePo4?
