Welcome to the forum. Several boaters lurk here....
First let me say, that chargers get quite expensive the more amperage they handle but you likely already found that out. Your likely thinking before dropping that amount of cash on one, you want to get it right. Good Common Sense at work ! 200AH @ 100A charge rate would be the normal max they would be charged at. You had better verify the cell info per the manufacturers data sheet on the cells. Higher charge rate will increase temps and significantly as it get's higher. The "usual" would be to use an Inverter/Charger with it taking "shore power", whatever that may be, be it genset or actual shore/grid.
To get a better response, I would suggest you verify & if possible post the cell data sheet here for people to see.
Maybe a brief synopsis of your system / gear that you have, Solar Controller, Inverter/Charger etc...
