apctjb
- Jun 16, 2020
- 471
Finally got my solar installed and able to charge at higher rates (~100A). As the day progressed the differential between my highest and lowest cells (cells 15 & 16) started to increase from about 20ma to max differential setpoint (100ma) I had set on my Chargery BMS, which triggered the relay and stopped charging.
So what are typically max cell voltage differential folks are seeing with EVE 280 cells at 100A rates?
Is there any harm in having higher cell voltage differentials? (as long as not exceeding voltage setpoints for any individual cell)
Hoping this is simply a busbar resistance issue. Will check torque on my busbar connections tomorrow.
