Hello folks !
I need help to set up my solar charge controller for a 24V Li-ion homemade battery.
Before I ask, I browsed this wonderful forum ( Thank you Will Prowse for that !
) but I only found set up for LiFePo4 battery, which is different from Li-ion ( 3.2V VS 3.7V )
In the custom mode of my SCC ( USER mode, right column on the picture ), I have to modify a lot of parameters, but I don't make a difference between some of them.
I would be grateful if someone could tell me what would a "safe" value for each parameter according the battery I want to charge ( for recall, a homemade 7S60P Li-ion battery, not a LiFePo4 )
I f someone can explain to me as clearly as possible what every parameter do, it would help me to take the right decisions about this set up ( I don't want my battery to be damaged, or worse, to explode, it's for using in a RV ! )
Thank you very much, I'm waiting for your advices
