Hi all,
I have two twelve volt LiFePo batteries that I'm reconfiguring to be 4 series of 3.2v (see image below), because I could only find a BMS that would accommodate a 12v 4s (using same BMS used in video link below). In doing so, I connected one set of batteries just fine, but when connecting the 2nd 12v battery, one of the cells would spark when connecting. I did a little research and found that this was caused by a difference in voltage between battery cells. Sure enough, I used a multimeter and while the three other battery cells were at 3.35, the fourth was at 10. I then tried to connect it again (to the one battery connected in series to the other two connected in parallel). Still sparked. I measured the voltage again...it seemed to go up to 16...then it went to zero.
I thought that I would just configure a 12v battery and use the BMS on that twelve volt battery to balance all of the cells per Will Prowse's instructions here:
. However, the BMS has been on the battery now for over 24 hours and nothing has changed. Any ideas?
Best,
James
Best,
James
