Pickuptrck
NV owner builder
As titled, I fell in love with paper-specs of the below inverter. Then I saw a post here where multiple users have seen a 155w standby draw.
No idea why that's in bold, sorry! LolMy ground array will have 10 acres to play in, so size is of no concern. Would a draw like this realistically cause great concern vs the 40w normal I see as normal with other units? Is there a unit similar to these specs 48v, genset start, off grid only, split phase capable, within a reasonable $3k cost range and good surge capacity?
SUNGOLDPOWER 12000W Peak 36000W Split Phase Pure Sine Wave Power Inverter,Low Frequency Inverter DC 48V AC Input 240V AC Output 120V 240V Converter, with 60A MPPT Solar Charger Controller 12KW
I've completed the solar audit, I'll post it tomorrow with the build version (many high amp startup tools) and the more stable daily use versions.
I didn't post a link to stay within normal forum rules. If that's not a thing, I'll amend the post tomorrow.
Thanks!
