I just received my Redodo 200ah Plus with 200a BMS. The battery arrived at 13.1v so I guess about 40%, I was told by them that it will accept up to 100 amps charging but they recommend 40 amps, so I am using a progressive dynamics 9160ALV which is 14.6v capable and 60 amps. I turn it on and the highest I can get out of the charger or into the battery is 43 amps, so I turn on the WFCO charger that is lithium compatible and 40 amps, went up like an amp. Its like the BMS is limiting the input charging amps. Also the voltage only got to 13.87v when it apparently was fully charged and the amps dropped to 1.3 Can anyone shed light on this?? Thanks in advance!
