Refrigerator UPS using a Growatt 3000TL LVM
Desert_AIP
I have an all electric house.
Several years ago I built a UPS for my refrigerator with a Cotek 24V inverter and charger. I used several relays directing the output so it would maintain the batteries when on grid power then auto failover to the inverter when there was a power outage. It provided about 24 hours of backup, and had an input for a generator to refresh the batteries.
The goal was to keep the refrigerator running if there was an outage while we were away, and to be able to run the refrigerator at night during an extended power outage so we didn't have to keep the backup generator running all night.
I spliced a twist lock outlet and corded plug inline the refrigerator circuit.
The circuit travels from the breaker to an outlet, then the corded side connects to the wiring running to the refrigerator.
I can either plug in to the outlet, running straight off the grid, or place the UPS in between the outlet and plug and have utility power and battery backup.
I'm using twistlocks specifically so they can't be knocked loose.
It worked, but took up a lot of space, and the charger wasn't matched well to the new LiFePo4 battery I built.
The box I built was 24x24x24 on 8" casters and took up a LOT of space in the garage.
I recently replaced the contraption with a Growatt 3000. I reused the LiFePo4 battery.
The new install is a lot cleaner, takes up less room, has higher utility charging capacity, is programmable for lithium batteries, and has PV charging option. So in an emergency I can set up the panels I have and keep the fridge running indefinitely.
I was able to install it in an out of the way corner in my garage.
I also included a derived load center with separate input and output circuit protection, and have a second outlet for a small fridge in the garage.
Old version
New version
I got ~32 hours until exhaustion in my test. I have a 24V 190Ah LiFePo4 battery now.
Once the inverter kicks on to supply the load, the efficiency increases.
I haven't seen much problem, but haven't metered it. It's doing what I want it to.
I need to do a long term, like over the weekend, test with solar only.
I have two 150W panels I hook up in series to feed it.
I need a couple larger panels to get by in Winter.
The fridge consumes around 2.4kWH per day.
Playing with this thing makes me want to permanently mount an array and run full time on solar with utility as backup.
4.56kWh battery
Fridge - average 100Wh/hr
3.2kWh fridge use
1.36kWh idle burn/inefficiency.
So, idle burn/inefficiency consumed 1.36/4.56 = 30% of your battery capacity.
300W of panels will be insufficient to provide indefinite backup power as that will only get you 1.5kWh/day with good sun. Likely need 900W of solar if you plan to use it for indefinite fridge backup.
That's what I think I calculated. 1KW min, which is what started me thinking of a permanent array.
I've built a couple smaller systems for camping.
I have a 54Qt 12VDC fridge and a 280AH 12V lithium battery. I run one of those 150W panels indefinitely. The fridge will run 5 days on the battery alone.
Old version
New version
Can you share the growatt settings for that? I’m trying to do something similar but finding I’m not getting the settings right yet. On grid it’s still pulling from the battery.
Old version
New version
@Desert_AIP Im planing on building a similar unit to your old system. Do you mind sharing the schematics.
I don't think I have my drawings anymore. Sorry. A lot of the planning was simple box diagrams, with me figuring out the details in situ.
I dont recognize these 3?
The one at the top is a time delay relay. To prevent short cycling the compressor on the refrigerator. When the line power comes back on, that relay has a 5 min delay before tripping to on and providing line power to the refrigerator.
Middle left is just a terminal strip so I can route and segregate the line and inverter 120v power. I needed to ensure the neutral was switched along with the line hot so I didn't back feed the grid or cross connect the inverter and line power outputs. One of the relays in the upper right switches the neutrals from line to inverter, the other switches the hots (IIRC).
The middle metal box is a line powered outlet the charger plugs in to. In the pic, it has an outlet tester plugged in to it to test the switching.
That pic does not have the DC side hooked up yet. So no battery cables to the battery from the charger, no shunt, no cables from the battery to the inverter, the charger is not plugged in to line power yet.
