Snowynorth
- Jan 10, 2022
- 217
BEFORE PURCHASING A REMOTE START GENERATOR YOU MIGHT WANT TO READ THIS.
Does anyone know of a portable, dual fuel/tri fuel, remote start, that won't drain the battery when using the remote, to shut it off?
I have a Hyundai remote start 3500 w, and had same in a 3200w that was stolen.
With a "proper break in" both were great right out of the box, with 100s of hours without a glitch.
When shutting off with remote the on/off switch would go into standby mode, and "NOT" drain the battery.
They had a 3 way switch, off/ center (remote start)/ and console start, which bounced back to center standby position.
I forgot to shut it off and left my 3500 once for 2 months, and it fired right up using the remote, with no apparent battery drain.
Now I'm looking for a bigger portable 7000w +- dual fuel for power and battery back up, while we build a small shop and install solar.
I will use it later for battery back up.
Everything I'm finding has a simple 2 way on off switch.
The remote becomes useless, for shutting it down at night, and starting, the next day, because I will need to walk out to the generator and shut the switch off, to prevent the battery from draining.
I tested one without knowing that is going back for a refund.
I shut it off at night from bed, and tried to start it the next day by remote.
In just over 14 hours, the battery was too low to even turn over the Gen.
That is excessive battery drain, while not running.
I have talked to a few manufacturers, and all say the same, the battery will drain, but they try to mitigate it.
They obviously know about the problem, but don't seem to want to rectify it.
What good is a remote start/stop, if I have to walk out to the Gen to start and stop it anyway?
