John Frum
Tell me your problems
- Nov 30, 2019
- 15,224
I have a very weird usage model.
mains->converter->inverter->load
Both the converter and inverter equipment grounds were tied to the dc negative busbar
I noticed that the ground pin on the converter plug and the ground pin on the inverter receptacle had continuity
This would be a problem for my planned usage model which is so kludge-ugly I won't describe it here.
That converter equipment ground wire was quite stylish and I will miss it but it had to go.
I guess the majority of diy installs leave the EG disconnected.
afaict an ac fault to chassis should trip the ac supply breaker.
A dc short to chassis would not automatically clear.
Are there any ramifications that I should be aware of?
