I'm looking for some information about how people that use compression go about removing/replacing one cell from a battery that has been under compression for a long time.
If you've done something like this please say how long your battery has been compressed and with which method, what amount of force? Did you charge or discharge the cells before releasing compression? Have you observed any swelling? And so on (any other findings you may have).
Why am I starting this thread? I have a couple of batteries with compression fixtures. I'm planning to reconfigure one (use it's current 8S cells into a new 16S battery) and replace springs with longer ones on the other. It would be much better if I could just remove the compression force for the duration of spring replacement than trying to fabricate some brackets to hold it together.
Currently I'm thinking I'll discharge the cells almost completely beforehand. As batteries "grow slightly" when lithium goes into the graphite matrix during charging. So in theory the cell should be at its thinnest when discharged.
What do you think?
What do you think?
