Renogy 200 ah vs SOK 206 ah lithium?
The new lower overcurrent threshold on the bluetooth version of the BMS is being discussed here: https://diysolarforum.com/threads/new-sok-bluetooth-bms-for-diy.33945/
Thanks, good to know that maybe my mistake was relying on information regarding the older BMS.
There are reports its 50 amps or 0.25C, not 25 amps like your are reporting, even 50 amps is much lower than it should be for a 206. My older non-bluetooth version will accept 110+ amps each without shutdown.
Thanks again, "25 amps" was a typo and should have been "50 amps" which is the same limit as the 100Ah battery.
