John Frum
Tell me your problems
- Nov 30, 2019
- 15,233
OK since you don't want to void the inverter warranty.
Disconnect the inverter from everything and run some tests...
Check for continuity between the chassis grounding lug and the ac ground.
I expect continuity.
Check for continuity between ac ground and ac neutral.
If both are true then you will need to separate all the ground and neutrals in the panel.
When your are done there should be no continuity between the neutral and ground busbar in the panel.
