TommyinMiami
- Apr 2, 2022
- 35
Hi guys, has anyone had this issue before with the Renogy app.
The app is showing 20-30 watts 2-4 amps LESS than actual power.
For example my panels right now are pulling 245 watts. My watter meter shows 245 18amps, my renogy shunt shows 245 18 amps, the renogy charge controllwr shows 16 amps and the renogy home DC app shows 14amps 220 watts. BT app is the same.
Inline power meter and shunt match up, the controller is slightly lower and the app is way lower.
From 5pm-8pm when I make less than 25 watts the app will show zero even though I'm getting 20 watts on average in late afternoon.
It's still passing power to the batteries but it's not correctly showing this.
It has been going on for 2 days. It's run perfect matched up for over a month since I got it.
Yes I've re booted, unplugged BT module, restarted app, tried both apps, tried a different phone.
Any thoughts on this. I knew I should've gone with victron If only their prices weren't so insanely high. Has this happened to anyone else before. I am just out of the 30 days return window ofcourse.
