I have two 175 w Renogy panels, a Renogy charge controller, a 2000w Renogy invertor, 2 100amp AGM batteries and a Go Power TS30 transfer switch
There are top issue. The first is that as soon as I turn in the GFI breaker the monitor shows the system using between 8 and 10 AMPS and 60 to 80 watts
draw. which of course drains the batteries quickly. This happens almost every time I turn on the GFI breaker. The reason I say almost every time, is that on two occasion this has not happened and the everything works just fine with a small AMP draw of .86 and a wat draw of around 10 since my refrig is on.
The other issue is that when this high draw happens the monito shows the system has no AH available with )% available. If I put on charger it resets with 0ne hour.
Any ideas
Any ideas
