Just installed my battery shunt and in a rush to leave for camping I didn't set it up to read my lithium properly. While on the trip it permanently showed 15a being pulled out of the battery, even if nothing was connected. Strangely when having the backlight of the monitor screen on it would pull 36a.
Figuring I'd stuffed something, came home to try and fix it. Moving the voltage sensor wire away from possibly interference was the first port of call but before I could get to it the monitor ran 'flat' (13.76v still in the battery).
Now I can't get the monitor screen to turn on again. I've tried disconnecting the feed wire, the shunt, the voltage sense wire but all to no avail. I'm currently running the battery flat to do the monitor settings correctly but it might be pointless if the screen doesn't work
