Okay, I'm not setting up the solar charge controller or the inverter yet. This is for my ham radio shack. Just 100ah lifepo4 batteries x 2 witha Renogy battery monitor to see how it goes first. The batteries are connected in parallel, positive to positive and negative to negative. The red shielded wire from the shunt is connected to the positive of one battery, negative cable from B- of the shunt to the opposite battery that the red shielded wire is connected to and finally the positive anderson pole from my load(radio and pi4) is connected to the positive of the battery without the shielded wire and the negative anderson pole from the radio is connected to the P- of the shunt. I put the total ah as 200ah. Everything seems to be reading correctly. Dud I do this right?. Thank you for replying and being kind on a newb just learning.
