I set up a shed with solar panels to power a 12v POE wifi setup on my acreage.
I used to run cheap 2x 100a lifepo4 batteries and never had an issue but I saw Renogy had their self heating batteries on sale so I decided to give it a try rather than passively insulate my cheap batteries.
ca.renogy.com
My main issue is that my setup doesn't draw more than 1a so every night the BMS goes into "shelf" mode and the battery reads 12.3v and I guess gets re-awaken by my Victron mppt controller at some point when theres enough sun.
It feels like a terrible idea and not at all explained in the manual.
So does that means that I run the risk of the mppt controller being unable to wake the battery up ? Can this set up last long term ? Can I bypass this by setting up a smart switch to run a 2a load for 15min every 12 hours ?
Also if the bms is in sleep mode and it gets below 0C at night ... will the self heating still works ? Is there a way to disable this "feature" ?
Core- 12V 300Ah Deep Cycle Lithium Iron Phosphate Battery with self-heating function
Meet Renogy 12V 300Ah Core Series Battery, your trusted, one-stop solution for upgrading from Lead to Lithium. Compatible with Renogy's solar panels, solar charge controllers, and inverters, this battery delivers a seamless upgrade experience without any compatibility issues.
