HandsomeSteve
Renogy charge controller won’t charge?
I’m just starting out w/ solar:
My renogy 10watt charge controller isn’t charging according to my new qwok battery monitor ,my lead acid battery.
Yesterday I connected my AC/DC inverter to charge my drills battery.
This process from the house’s AC120VAC usaley takes around 40minutes about the same amount of time w/ invertor.
Started this charge w/ battery at 98.5%. the invertor was sucking 5amps to charge drill battery. After the 40 minutes battery dropped to 96.9%.
last night the two LEDs lights where on for 4 hours only sucking .3 amps in morming the battery was at 94.9%.
This morning the panel was putting out 12.8 volts however after 6plus hours. the battery hasn’t increased it’s %.
Additionally the USB ports won’t charge a USB devise.
Could my charge controller be defective?
Maye I should step up to the eco worthy 30amp? I believe it has the programmable timer load I want. This.
https://www.amazon.com/ECO-Worthy-Controller-Intelligent-Regulator-Negative/dp/B08JBLMC33/?_encoding=UTF8&pd_rd_w=OdSlB&content-id=amzn1.sym.255b3518-6e7f-495c-8611-30a58648072e:amzn1.symc.a68f4ca3-28dc-4388-a2cf-24672c480d8f&pf_rd_p=255b3518-6e7f-495c-8611-30a58648072e&pf_rd_r=PDZ6HN42X2FXFCZC64ZR&pd_rd_wg=rYre6&pd_rd_r=17a2d677-57ff-4dfb-b479-269436281912&ref_=pd_hp_d_atf_ci_mcx_mr_ca_hp_atf_d
Or this I like the current being displayed but unsure if it has the programmable timer load.
https://www.amazon.com/GHB-Controller-Intelligent-Temperature-Compensation/dp/B01LZZMDSQ/?_encoding=UTF8&pd_rd_w=Gd0wf&content-id=amzn1.sym.255b3518-6e7f-495c-8611-30a58648072e:amzn1.symc.a68f4ca3-28dc-4388-a2cf-24672c480d8f&pf_rd_p=255b3518-6e7f-495c-8611-30a58648072e&pf_rd_r=9AGBP640ZA3QEW6GD1NH&pd_rd_wg=nbQU8&pd_rd_r=ac6715da-d499-4975-bed6-611f9eb85226&ref_=pd_hp_d_atf_ci_mcx_mr_ca_hp_atf_d
thanks for advise
thanks for advise
