Renogy DC Battery Charger - Alternator Wiring
Hi,
I am wiring this system https://www.mobile-solarpower.com/simplified-400-watt-fewer-wires-and-alternator-charging.html and am having trouble with the alternator output wire.
Should the alternator output be wired to the DC Battery Charger Alt+ terminal or should the alternator output be wired to the starter battery / bus and the Alt+ from the charger wired to the starter battery?
Any assistance is appreciated
Your alternator output connects to your start battery.
Thanks for the advice. Could the alternator output be wired to a battery switch or bus rather than the starter battery post?
