I'm not sure if I have an issue or an unlisted feature. I wanted to run it by you guys. I have my set up wired almost exactly the same as Will has it on his website. Slight variations, but same outcome. When my house battery is fully charged, and the dcc50s is charging the starter battery via solar panels, I am observing current draw from my house battery when there is draw on the starter battery. For example, when I open my door and the interior cab lights come on, I can see the current coming out of my my house battery via Victron bvm712. When I put my foot on the brake pedal and the brake lights come on, when I turn my head lights on, etc., I can see the draw on my house battery. This happens when the truck is in the off, accessory, and on position, but not when the truck is running. When I start my truck, I can see a spike of about 20A drawn from the house battery, then the charger starts charging the house battery from the alternator. The dcc50s seems to be assisting the starter battery with the use of the house battery, when charging the starter battery via Solar (Indicated by the flashing red light next to the alternator symbol). My assumption is that if the draw on the starter battery exceeds what the solar is putting out, it takes power from the house battery. I'm not sure if this is a bad thing or a good thing. Is this a feature, or do I have a bad unit? Technically it is battery isolation, but the charger is charging the starter battery via the house battery. Thoughts?
