Okay! Renogy called back. Here is a synopsis of the questions I ask and their answers.
Q1. Can a AGM or FLA battery be use as the starter battery and lithium as the house battery?
A1. Yes, no problem. Just don’t mix FLA, AGM and lithium together while on the same charger circuit.
Q2. How can I charge the house battery with shore or AC power?
A2. Connect house battery charger circuit to the +/- terminals on the starter battery. Get a inexpensive but quality battery charger and mount/connect it to the starter battery in the engine compartment. Plug it in, when the starter battery hits the correct voltage it will start charging the house battery via the Renogy DCC50S.
Q3. how do I tell if my alternator is a smart alternator or a regular alternator?
A3. Just hook it up without a smart alternator wire, if it works then you don’t have a Smart alternator. It will not harm anything. "Or use RandyP’s suggestion above."
Q3. In lieu of the worldwide "Beer Virus" should Renogy customers, after coming in contact with their products, sanitize or sterilize external extremities as well as their internals components with alcohol based liquid refresh... I mean... products?
A3. While the Renogy CS Rep apprised me that his was not a medical opinion the answer was . . . "Why not?” Beer was his preferred product as it hydrates while sanitizing.
p.s. Recently Renogy has moved all of its workers to home-based work and their new phone system is not acting properly.
