OneStudPuppy
- May 18, 2022
- 84
Open letter / discussion
@Renogy Solar you guys are so close to having a really solid company and product. SO CLOSE, but as someone new to the game I have some things which come to mind. Think of this as a customers open letter which others can add to.
I’ll do this in a list type format kinda makes it easier for me to run down my thoughts.
1. Quality control, now I get with production numbers you probably can’t test every unit that goes out. (BUT IN EMAIL I WAS TOLD THIS IS DONE) Clearly it’s not so, don’t claim it.
2. Tied into Quality control, example Rover 20amp controller. After finding mine was off about a volt or so I searched around. There is many posts about this. It’s close but “close enough” works in horse shoes but not so much when it comes to power system. With a common thread being that 1 volt variable. I’d expect there must be a common bond across these. A Engineer should be able to track where this is caused in the system.
3. Customer service teams and communications. I am not sure if you have a mix of staff in different locations who don’t work as a team or share notes on a case?
Example was my case with the defective wanderer. Over all replies went from let us reach out to another department by email and wait to hear back. The next reply mentioned maybe my system was too strong for the controller (single 100 watt panel, 100ah lithium battery). Then another email saying hey sorry about that other member they were not trained, and we will exchange the unit.
4. Customer service tied in, remind people answering emails to think outside the box, not every case will follow a employee manual work flow chart wise, example. My trying to warn you guys that your controller box is simply thrown in a plastic bag and no protection at all. Luckily your internal foam saved my controller from direct impact but unknown G forces of obviously several impacts. I think the 2nd or third reply someone got it and forwarded it on (hopefully to the amazon sales team)
5. Manual / documentation: I would be happy with a over load of technical information instead of a lack of information. I was able to email and had to ask about the Rover 20a and the max amperage output instead of reading in the manual don’t hook up a inverter or battery charger. That in the manual didn’t help other than state indirectly don’t overload the load connections.
6. Customer trust. Going back to the above post about the wanderer defective unit in a couple ways, and the .11 volt variable of battery vs controller is stating voltage is also strange 12.8 when I know hasn’t been that much draw in the time allotted. Makes one second guess a product, example I am currently looking into battery monitors with a shunt, with one defective item and the next seems to be working ok BUT with a variable it makes one question buying the next product or just 100% trusting the accuracy of it.
Again, I get it Renogy is a company in the end of days and run for profits but same time it seems to be a brand I hear more about and 50/50 on good vs it’s ok BUT. I may be one voice as I type this but I am sure others feel the same and with fine tuning and getting issues handled can bring that reputation and impression higher which would probably also result in higher sales.
Wish the company nothing but the best and welcome anyone else to give some input in a feedback yet constructive I hope.
