Per the title Im looking to redo my factory Solar Flex 400i to get a bit more flexibility and still run an ac.
I have two Victron mppt one 150 | 70 and the 2nd the factory victron smart solat 100 | 30. I am planning to replace the the 12v 400W array with two 24v 250w panel arrays from Rich Solar feeding each mppt. The fist array is 9 panel( 3 strings of three in parallel). 2nd array is just two panels. Im reusing existing keystone wiring. My two Mach 15 Q have soft start but I only expect to run 1 at a time when boondocking. Factory solution had a xantrex 2000w inverter with built-in transfer switch which I'll replace it with a single Victron 24V MultiPlus-II 5kVA 120V Inverter – 95A Charger to avoid issues with power assist when running two inverters and a 15amp house cord while moochdocking. Factory solution includes victron shunt which I'll keep. ll add cerbo gx and touch 70. Ill add a single victron Orion 24v to 12 converter.
I intend to remove the two factory Dragonfly 100ah batteries but Im torn on what to use to replace them. Battleborn are just way too expensive for me. Two Epoch Elite 24v 230ah (460ah) still seems pricey given recent issues/reviews plus I can get 3 eg4 LL 24v 200ah (600ah) for only$200 more than epoch.
Looking for feedback all around as Im sure my choice of setup is a head scratcher for some and Im not ashamed to admit Im possibly overlooking something.
Thanks!
Thanks!
