John Frum
Tell me your problems
- Nov 30, 2019
- 15,233
Do you have a hymer?I'm looking to achieve the same set up with 600-700 ah of lithium. Have you gotten any confirmation of this being the correct/ safe setup?
The hymer has very complicated electrics.No. I'm working with a ram bro master period but I'm pretty familiar with the internals of the engine and could at least use the Hymer as reference
Its your money and I thank you for your contribution to the economy.FYI, I decided to replace the majority of the electrical systems and have purchased the new Victron Multiplus, Cerbo with touch display, REC Active BMS, Wakespeed regulator, and 16 280 ah cells from Amy. I'll update the thread as I move forward, but should have everything but the batteries by the end of this upcoming week. Battery cells will be here by the end of the month per Amy.
Your original post of "Sounds like a huge waste of money." before you changed it to the above was not helpful. Your earlier post on this thread on Monday of not knowing what a Balmer actually regulates indicates to me you don't have much experience with this kind set up. I could be mistaken though as I don't know you and will reserve judgement about your knowledge base and the worth of your opinion on the subject matter. Perhaps you could elaborate on how you would have approached the situation of wanting bulletproof reliability, granular control of variables, and a much larger battery bank? That kind of post would be very helpful and contribute in a meaningful way to others on the board.Its your money and I thank you for your contribution to the economy.
I would have inventoried what you have and verified its configuration.Perhaps you could elaborate on how you would have approached the situation of wanting bulletproof reliability, granular control of variables, and a much larger battery bank?
Do you actually have specific recommendations based on the information presented? What I really want to know is what specific aspect of my new build you would have changed in the interest of not being a "huge waste of money". Let me know if you need any additional information about my old/new setup and what my goals are for the build. I have no problem with you being critical if you have actually have something useful to say. If not, move on.I would have inventoried what you have and verified its configuration.
Then determine what you need starting with an energy audit.
Then create a solution based on requirements.?
No, I suspect that starter batteries and the house batteries are not in parallel.Do you actually have specific recommendations based on the information presented?
They are not in parallel as stated in the original post. Feel free to private message me if you need further details if you have a sincere interest in helping rather than making useless negative comments. I will update this post with your advice in this thread afterwards to help others that find themselves in a similar situation. If you disagree that your original post, which stated "Sounds like a huge waste of money." before you changed it, was a useless negative comment, please feel free to PM me as well and we can debate the value of your comment in private. Thanks.No, I suspect that starter batteries and the house batteries are not in parallel.
Will you please check that detail?
That would be a first step in the inventory and configuration validation.
did you top balance those cells?
good to see you won't be in a hurry... so so many are like it has been 8 hours and the voltage isn't moving...View attachment 49541
Not yet, but I’ve got them ready. My dc power supply comes tomorrow and I’m ready to just sit on them for the next week or so while they balance. Probably should charge in series and finish in parallel to save time though. I may change gears later, but I’ll be pretty busy with work over the next week anyway.
upgrade the wire...
Thread 'Top balancing why proper wire' https://diysolarforum.com/threads/top-balancing-why-proper-wire.17168/o
looks good 12v 1120ah? (should be 14.6KWH)Got the majority of system installed, but I still have to clean up and label the wiring. I have aluminum/hdpe bars that will go across the cells locking them into place. Still waiting on a few fuses before going live this weekend.
Yeah, it’s a bit much.looks good 12v 1120ah? (should be 14.6KWH)
