Hello all. New to solar, started off with a solar kit which I assembled per their diagram but was never happy with it. It was an MPP Solar LV2424, 10-200 watt panels in two strings of 5 paralleled, two LiFePO4 batteries. It would revert to utility, usually on hot days but not always. So decided I needed a better system.
I have now ordered a MPP Solar LV6548, have 4-LiFePO4 batteries, and 12 200-watt Rich Solar panels. VOc is 24.3V, Isc is 10.2A on the Rich Solar panels and plan on using since I have them. I have studied the manual and read many posts and have come to the conclusion I can run a string of 9 of these panels, then once I order 6 more can run another string in parallel, giving me two 9 panel strings in parallel which should keep it within range of the inverter and would plug this array into one of the two SCC. Am I correct in my conclusion?
Another question, for the second SCC input, can the string be of a different type and more wattage so long as I stay below the limit of 250v total and in the 20 amp range?
Thanks for any advice.
