Researching Shed construction details for RE Systems - am I in the correct sub?
Old_Skewler
NYS
I am looking for layout designs and construction information to build a 4 Ft x 6 Ft shed to install batteries + inverter+ charges + disconnects & appurtenances.
Am I in the correct sub folder? If not, which sub would be more appropriate?
TIA!
I don’t know if you’re in the correct place, but I fit my RV inverter, SCCs, Busbars, Combiners, circuit breakers, and 13.3 kwh of 24 volt batteries in a pass through storage and it took up about 4 feet wide, 3 feet deep, and 2.4 feet tall. I wish I had a shed to put it in.
Thanks for the feedback. My equipment list is comparable, with a Magnum 4kw Inverter, Victron Solar Charger 60A, AGS and BMS and disconnects in addition to (4) 200Ah 12V. I believe 4ftx6ft shed would work fine too.
