I added a sub-panel to power ten circuits with a gas generator. I would like to add batteries as a first line of defense as well as add five solar panels on the ground in my yard to add whatever electricity I can to reduce grid electricity costs. The gas generator would be used to recharge the batteries if I have an extended grid outage. Should I add a circuit in the main panel to receive the solar input and not have it part of the sub-panel side?
I have the electric wire running from the sub-panel to the outlet outside for the generator. Should I disconnect that wire from the sub-panel and put an outlet on the generator wire that I can plug the battery into (like an EcoFlow Delta)?
Should I put an outlet on the sub-panel input that the battery could plug into (or should I hardwire from the input to a plug type the battery requires)? When I am using the battery, can I just fire up the generator and the battery system will just take the input and recharge the battery or do I have to worry about the order of plugging it in (fire it up and then plug in)?
Thanks
Thanks
