Simersam2004
I have had four of these Ecoworthy 48 volt batteries in parallel attached to my LV6548 for approx. 1.5 years.
Went to my basement to day and found it full of smoke with one of the four spewing a thick stream of smoke, after shutting down the inverter I cut the leads to the smoking battery and dragged it outside.
Now I'm a nervous wreck about the other three should I keep using them? The steel case seemed to do it job containing the fire but I don't know how bad it would have gotten if I hadn't been home to remove it.
Edit. Just after I took the pictures I buried it under a pile of dirt with my brothers track hoe that he had near my house.
Edit #2 Dug it up and added photos of the damaged inside.
There is a pool of melted stuff at the bottom of the case and the one lead is completely free from the the top of the battery cells I'm assuming it was soldered and melted loose.
Edit# 3 Ecoworthy Replaced all 4 of the batteries
