ericatb8a
I've been using a SunGoldPower 10kW offgrid AIO in Utility Bypass mode for my critical loads, trouble-free for weeks. Recently added a Growatt MIN 5000TL-X to the mix, connected via a 20A breaker, feeding into my critical loads. During an early morning test with only ~200W from solar, all was fine. Post-test, I disconnected solar and stepped away, thinking the Growatt would be inert.
After about 20 minutes, I came back to a burning smell. Logs showed a 5.5kW surge from the Growatt, apparently pulling from utility, overwhelming my off-grid setup and risking an electrical fire.
Anyone else faced this or know why it might happen?
9/26 Thursday Update: The burning smell issue returned on Tuesday morning, even though Growatt was disconnected since Sunday. This confirms the problem is with SGP, which we've now taken offline. We've been running on utility power without any issues for almost 48 hours. I'll be reporting this to SGP.
**Update 10/17/24:** After further tests and a consultation with an AC technician, I've identified the issue with my MrCool Split AC system. The problem arises from rapidly cycling the unit on and off. Apparently, this can cause the small oil-filled motors inside to enter a state of confusion, leading to attempts to start without fully succeeding, which in turn can cause them to heat up thus the burnt oil smell. This issue persists even when the AC is not on but the power cicuit is energized. The solution is to completely shut down the AC's power circuit anytime that I might need to cycle the house power. And wait at least 15 minutes before turning it back on.
