RollingThunder
- Feb 24, 2021
- 58
Hello everyone,
I just received my panels, 250w T series snail trails, from Santan Solar. The package was undamaged, and I tested the panels immediately after unpacking. It was between 11am-noon, sunny, hot, about 100f degrees. I tested one panel at a time, laid flat on some unistrut, on a concrete pad, so each panel was set on the exact same place, one swapped out with the next as quickly as I could do so. I tested each parameter for only 10-15 seconds before moving on to the next due to the very hot conditions.
According to the sticker:
The panel model is ss250p-60.
The VOC is 37.6v
The IMP is 8.27.
Test results of all 9 panels:
1. 34.4v,8.5a (292w)
2. 34.4, 8.49 (292)
3. 35, 8.55 (299)
4. 34.7, 8.6 (298)
5. 34.5, 8.55 (295)
6. 35, 8.6 (301)
7. 34.3, 8.7 (298)
8. 34.9, 8.69 (303)
9. 34.5, 8.73 (301)
These are my first solar panels, and the numbers seem good to me, can others validate that these are good to go?
Thanks!
The VOC is 37.6v
The IMP is 8.27.
2. 34.4, 8.49 (292)
3. 35, 8.55 (299)
4. 34.7, 8.6 (298)
5. 34.5, 8.55 (295)
6. 35, 8.6 (301)
7. 34.3, 8.7 (298)
8. 34.9, 8.69 (303)
9. 34.5, 8.73 (301)
Thanks!
