I have been designing and now purchasing components for my RV system. I will have 3 separate 48v batteries. Each battery will be 16s x 3.2v x 180a. I was intending to purchase three Victron Battery Protect 48v-100a. These would be installed between each battery and the central bus. The BMS for each battery would be programmed to "trip" the battery protect in case of under voltage, over voltage, over temp, under temp, and cell imbalance.
The central bus would also have the charger/inverter connected to it. The documents from Victron state : "* The BatteryProtect is not designed for reverse currents from charging sources." Does this mean the current can not go back through the battery protect from the central buss to charge the batteries? If so, I don't understand the purpose of this device. I can't get my mind to wrap around an idea of being connected to a system for a discharge scenario, but not for charging. Unless you start including massive diodes.
I am also looking for recommendations on a quality BMS that will meet these parameters for each battery.
