Hi forum!
So I am in the middle of reviving a "broken" BYD 11kWh battery pack, that will be used with a Fronius Solar inverter.
Backstory, the pack was left at 0%SOC at -25C and not really wanting to work after that, tripping main breaker. So I dismantled the pack and most cells range between 2.6V and 2.9V. This to me looks like a possible undervoltage situation, which trips the BMS to not undercharge the cells further. Normally they shouldn't be discharged to 2.6V AFAIK?
So now I'm charging up the cells individually before attempting to restart the battery. I set my LiPo charger to 3.3V programme to save time. Due to the flat nature of the LiFePo4 chemistry, will this be OK, or should I go for higher voltage? Really new on this chemistry, been mostly using LMO. Any tips at all appreciated
