Risistor
So, i just have on on off switch to acticate my inverter, no resister. this on every camping trip with my RV.
Just crank on the switch for the inverter to the battries, then crank the solar switch on. No resistor.
Where are you located at?
What is your system DC Voltage?
I live in Esbjerg, Denmark
And use a 12 volt solar system whit a 1000 watt inverter.. but the system is 11 years old and is thinking and switching to LiFePO4 batteries ..
47 Ohms 5W (or higher Wattage will be fine) resistor will be fine, it will limit the maximum in-rush current to about 0.25A
