mr.derekmmartin
lefty on BullShoals@BeaverCreek
help please, while trying the Ecoflow River 3 and River 3 plus as a ups for pc they both seem to be working correctly (pass thru) but with the units set at 80% charge limit the battery level fluctuates between 78 and 80% very slowly dropping and retopping off is this normal? Ecoflow seems to think so but if pass thru is truly working should the battery percentage be dropping at all? I would imagine the inverter running is doin its regular power draw but if it's not touching battery why does it drop?
thank you!
thank you!
