robbob2112
Doing more research, mosty harmless
Anatomy of a MCCB - this one was $36 on aliexpress
With the cover off.
The arc chutes, 1/2" wide and 1.25" tall
Where the arc chutes go.
Very good quality and I wouldn't hesitate to trust it as a switch.
Below are some additional brands
Top quality is TOMZN closely followed by TAIXI.... then the ZOII but it doesn't have lubricant at the moving points... and the BAOYI in a distant last place.... CHINTZ comes in below the TAIXI and TOMZN but higher than the ZOII
All of the ones I have in my possession are marked for line/load in one way or the other --- they are polarized..... This tracks with only having arc chutes at one end...
the big 4-pole breaker on the left also includes a 24v remote trip relay so it can be controlled by a dry contact off an inverter or code red or cerbo GX box....
The Baoyi seems to be made from much lower quality parts, the top/bottom shell don't mate up totally evenly and it wouldn't surprise me if it came from the reject pile and was sold then relabeled.
The ZoII seems a bit better quality but lacks lubricant inside it so to me that means it might not trip at the rated current if there is corrosion present.
The Taixi and the TOMZN are both really good quality inside and out -- DiH00l (note that is zero zero verse 'o' 'o') -- is the same parent company as Taixi ...
I checked with a file and all of them have tin plated copper where the bolts go in.... I went deep enough to get through the plating when checking since a lot of the fake bus bars out there are brass that is copper then nickel plated. When plating brass nickel makes a dull pitted finish if you don't first plate it with copper.
I got the Taixi and TOMNZ off AliExpress and the other two came from Temu -- which tracks because a lot of the stuff I have gotten from Temu is marginal quality where from Aliexpress I seem to get exactly what I order.
My preferred brand is the TOMZN black version -- it has the highest AIC of the bunch
With the cover off.
